AutoCAD Forum
how to change properties through macro/automaticly?
3 REPLIES 3
Mees210503
494 Views, 3 Replies
Mees210503
hi, when using a dimension line horizontally it also puts the text horizontal. but because that takes up to much space we like to put it vertically (go to properties > text > text rotation > and set it as 90 degrees)  but this takes so much time when working with 100+ dim lines. is there a way to get a macro to change the properties. or some other way to automatically change the text rotation of a dim line?   ill attach a picture of the problem! thanks in advance!
edit: the problem only occurs when draggig the text. when dragged it automaticly changes to its horizontal positsion.
Labels (1)
  • Q&A
3 REPLIES 3
Valentin-WSP
in reply to: Mees210503
Valentin-WSP
@Mees210503 ,
Dimension styles does not have a text rotation option.
Here are a few ways to do a mass dimension text rotation.
  • SELECTSIMILAR (Command) or QSELECT (Command) and then Rotate text thru Properties
  • MATCHPROPERTIES (Command)
  • Select "text ANgle" when dimensioning (except you have to do this each time)
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
@Mees210503 ,
Emilio Valentin
j.palmeL29YX
j.palmeL29YX
Try this LISP  (quick and dirty) :
(defun c:DTV (/ pi-2 ss number ent edat)
;;; DimText vertical
  (setq pi-2 (/ Pi 2))
  (princ "\nSelect Dimensions: ")
  (setq ss (ssget))
  (setq number (sslength ss))
  (repeat number
    (setq number (1- number))
    (setq ent (ssname ss number))
    (setq edat (entget ent))
    (setq edat (subst (cons 53 pi-2) (assoc 53 edat) edat))
    (entmod edat)
HTH
Jürgen Palme
  (setq ss (ssget))
  (repeat number
    (entmod edat)
HTH
Jürgen Palme
Mees210503
in reply to: j.palmeL29YX
Mees210503
you are my hero! thanks!
AutoCAD Inside the Factory
