AutoCAD Forum
how to change color of layout grey background
6 REPLIES 6
8045 Views, 6 Replies
Hi, how to change the grey background color of the Layout Tab?
I know how to change the sheet background color but i couldnt find how to change the big grey background color. I once used it with a black background in someone's computer, so i thought its possible to change it.
Thanks! 🙂
6 REPLIES 6
Kent1Cooper
OPTIONS command; Display tab; [in 2015 -- there may be variants in other versions] Window Elements area; Colors... button; in the Context: list, Sheet / layout; in the Interface Element: list, Uniform background; pick your color from the Color: pull-down list; Apply & Close button at the bottom; OK button in Options.
Kent Cooper, AIA
in reply to: Kent1Cooper
Hi Kent1Cooper,
Thanks for your response. And yea, I knew how to change the paper background (as what you wrote down).
The thing im trying to figure out is how to change the grey area outside the paper sheet, not the paper background itself.
do you know how to do it too?
Thanks 😄
Kent1Cooper
I don't.  It may not be possible, since Sheet / layout is one item in the Color settings' Context: list.  If Sheet and Layout were separate items....  Or it may possibly be something that's controlled by Windows settings rather than AutoCAD settings.
Kent Cooper, AIA
okay. Thanks so much 🙂 Kent1Cooper
Just go to Option: Display Tab > Layout elements > untick the Display paper background. That is 😉
Thank you!
AutoCAD Inside the Factory
