Hi, how to change the grey background color of the Layout Tab?
I know how to change the sheet background color but i couldnt find how to change the big grey background color. I once used it with a black background in someone's computer, so i thought its possible to change it.
Thanks! ๐
Thanks! ๐
OPTIONS command; Display tab; [in 2015 -- there may be variants in other versions] Window Elements area; Colors... button; in the Context: list, Sheet / layout; in the Interface Element: list, Uniform background; pick your color from the Color: pull-down list; Apply & Close button at the bottom; OK button in Options.
Hi Kent1Cooper,
Thanks for your response. And yea, I knew how to change the paper background (as what you wrote down).
The thing im trying to figure out is how to change the grey area outside the paper sheet, not the paper background itself.
do you know how to do it too?
Thanks ๐
Hi Kent1Cooper,
Thanks ๐
I don't. It may not be possible, since Sheet / layout is one item in the Color settings' Context: list. If Sheet and Layout were separate items.... Or it may possibly be something that's controlled by Windows settings rather than AutoCAD settings.
okay. Thanks so much ๐ Kent1Cooper
Thank you!
