AutoCAD Forum
Publish - unknown command
2 REPLIES 2
619 Views, 2 Replies
I have Autcad Lt 2017 -- and I cannot get the publish command to work the response is "Unknown command "Publish" this worked in the 2016 version
Title edited for clarity By
Sofia Xanthopoulou
Sofia Xanthopoulou
2 REPLIES 2
Sofia.Xanthopoulou
Sofia.Xanthopoulou
Hi klenz,
and welcome to the forum Smiley Happy
This issue has been resolved in this discussion. Please report back if it worked for you as well, to also mark the accepted solution in this thread.
Thank you
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Hi klenz,
Thank you
Tags (1)
Sofia.Xanthopoulou
Sofia.Xanthopoulou
Hi @Anonymous,
you never came back to thread. Did my link to the other discussion work for you?
Most likely this is an installation error. And I'd like to give you again the basic steps for a proper installation:
  • Download the Software  rather than installing it directly.
  • Disable Virus scan
  • Make sure you are an Administrator
  • Have User Access Control turned off (UAC)
  • Run as Admin
  • Reinstall the software
This should resolve the problem. Please mark one of the post as accepted solution if this worked out for you, so all other readers can benefit from your experience, too.
Thank you
Hi @Anonymous,
  • Run as Admin
Thank you
AutoCAD Inside the Factory
