AutoCAD Forum
How do you hatch a 3-D object?
4 REPLIES 4
bushbapd
276 Views, 4 Replies
I created a simple box using the 3-D tools tab. A 2' length, 2' wide, and 2' high box. I want to fill the box with a yellow layer. When I go to hatch it, it hatches the bottom face only, but for the other faces, it gives me an error "A closed boundary could not be determined." I'm using AutoCad 2025. How do I go about this?
4 REPLIES 4
Valentin-WSP
in reply to: bushbapd
@bushbapd ,
May want to explore Material Definitions:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
bushbapd
in reply to: Valentin-WSP
Is that based off the 2025 version? I can't find the material definition section. Or the style manager
a_meteni
You'll need to align the UCS with the 3D face first and repeat this with each 3D face you want to hatch.
Valentin-WSP
@bushbapd ,
Once in the 3D Modeling Workspace, Open the Material Browser, then drag the desired type onto the 3d solid.
Emilio Valentin
Forma Design Contest
AutoCAD Beta
