I created a simple box using the 3-D tools tab. A 2' length, 2' wide, and 2' high box. I want to fill the box with a yellow layer. When I go to hatch it, it hatches the bottom face only, but for the other faces, it gives me an error "A closed boundary could not be determined." I'm using AutoCad 2025. How do I go about this?
Solved by a_meteni. Go to Solution.
May want to explore Material Definitions:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Is that based off the 2025 version? I can't find the material definition section. Or the style manager
Once in the 3D Modeling Workspace, Open the Material Browser, then drag the desired type onto the 3d solid.
