Why the heck do the creators of autocad think highlighting the whole xref as a block is helpful? I want to be able to select individual lines like in Microstation. Is this possible?
Sorry it didn't help....I've never used Microstation, so just taking a guess. I don't think there is a way to do what you are asking, but someone with more knowledge than me might be able to help....
>> (autocad gave it a shot with "NCOPY" command but it sucks)
In AutoCAD this limitation -that you don't like- is the power of using Xref's . it's kind of guarantee for your references to be in safe and untouchable . Sometimes .. i wish that i have a lock to prevent others from making modifications for attached xrefs . This is the other angle of your issue. 🙂
All the best ...
Imad Habash
Well you would think they would make improvements instead of changing the logo every two years.
☺ ☺ ☺ Definitely, not much improvement for the fee they whack you ☺ ☺ ☺
There is an old LISP routine called "Probe" that does a better job than XLIST, but it's pretty cryptic to read the results.
If you are just looking for the layer of the object in an Xref, you could use the PickLayerOff command and look at the command line to see which layer it turned off, then UNDO. Not terribly elegant, but it's quick and easy. Two picks and a Ctrl Z.
Other suggestions like Edit Reference in Place or Open Xref (both from right clicks on Xref) will work too, but can be a pain if the xref is huge.
Bottom line, no, there is not a built in way to do this like you can with MicroStation.
Just curious what is it, exactly, you are trying to do? What properties are you interested in of the Xref's entities. I've seldom needed this feature.
@Anonymous wrote:
Im not trying to edit the reference. In microstation, you can select individual referenced lines, you cannot do anything with these lines unless you want to copy them in using the simple and norma copy comman (autocad gave it a shot with "NCOPY" command but it sucks) , and it will give property info at the bottom of the screen of what reference and what layer lines are on, It doesn't automatically select the whole reference.
If that's all you're after is the xref name and layer name of a particular line, it's truly a very, very simple solution. All you do is pick the "Freeze" layer button. Your command line will tell you exactly the xref and layer names of the object you just selected.
It sounds like you just want to complain and don't care about a solution. The complaint department is down the hall and to the left.
If you are here for a solution, tell us what you want to do with the selection. The way to do it in AutoCAD will be different from that other software and it might be an extra step or two but you can get what you, just not the way that other software does it because, well, it's a different program.
Its not necessarily a command. If you have ever used microstation, you can click on specific lines in the reference to copy (just normal copy) them through for their properties, or if hover over said line, it will give you the layer and xref it is located in.
In autocad the whole thing just highlights which is not helpful at all, even when youre trying to click on other lines. If you use "Ncopy" you can only pick one line at a time.
If you can turn off the "whole selection" for groups or blocks in a drawing, why would you not be able to do that with reference?
I do civil design, i can have 100s of layers with lines that look similar, its a lot easier to sort through or work in a file when it doesnt just randomly highlight the whole reference for no reason.
Comparing nuances between platforms and trying to use it as an argument about how useful a program is holds no weight to me. Learn to use the program with the tools available and you won't get frustrated.
Just because you can't do something the way you think it should be done or can do in a different program doesn't mean that there is a valid workflow for what you desire.
I'm not going to add any more suggestions because it's obvious you don't want solutions other than the way you think it should be done.
@RobDraw wrote:Just because you can't do something the way you think it should be done or can do in a different program doesn't mean that there is a valid workflow for what you desire.
This should read, "... doesn't mean that there isn't a valid workflow..."
So, instead of complaining about it not being possible, ask about how people accomplish it.
