AutoCAD Forum
How do I insert multiple .sid files in AutoCAD 2020?
1 REPLY 1
618 Views, 1 Reply
I am a complete AutoCAD rookie, so I apologize if this question has already been answered or if its answer is common knowledge.
I am looking to import more than 50 sid files and each file is located in its own folder.  Rather than manually going into my Raster Tools and Inserting a each new image, and changing each image's dimension, is there a way to import a batch .sid files?  I found this post from seven years ago but it has a dead link and doesn't seem to have an answer.
Thank you all!
Andrew
1 REPLY 1
ennujozlagam
MAPIINSERT or Convert the .sid file into a 4-Band RGB image and see if helps. thanks
Forma Design Contest
AutoCAD Beta
