AutoCAD Forum
how do i draw a straight line with 30º inclination without using the ruler?
4 REPLIES 4
1395 Views, 4 Replies
i have to draw many 30º straight lines and using the ruler becames tediousif i press shift and draw it makes a 0º or 90º line if i press D it makes a 45º degree
but are you gonna tell me theres no a simple way to make staright lines of any inclination?
btw im trying the free version but after this trouble i really doubt i purchase full version
4 REPLIES 4
pendean
Free is the same as the puchased version, are you new to AutoCAD?
- You can turn on POLAR in AutoCAD, set it to 30 degrees, and draw.
Or rotate your UCS 30 degrees.
Or DVIEW command's TWIST to 30 degrees.
in reply to: pendean
You can also you "snapang" to set your cross hair angle. AutoCAD has multiple ways of doing so many things.
jggerth
And if you are trying to create an isometric drawing, explore SNAP Styles, and set to isometric.
This is not a program you're going to learn in a couple of hours, take a class, watch you tube videos, buy a book, etc. good luck
AutoCAD Inside the Factory
