how Create a hatch pattern with different solid color in different boundary?
rahmanmuntasir_saudi_qs
Observer Observer
Observer
Observer
i am trying to make a hatch pattern for brick wall, where i will need two different color in in two bricks, is there any way to make it?
see the attached file plz
pendean
Community Legend
Community Legend
AutoCAD HATCH patterns cannot contain colors. Sorry
if you installed Express Tools (and are not an LT user), try the command SUPERHATCH (usage nd limitations are explained in HELP).
Ed__Jobe
The only way you could do it with hatch is to have multiple hatches for each brick, or at least 2 hatches, one for each layer color and manually select each brick. Either way is tedious. If your wall is 3D, you can assign a material to it that is an actual image of bricks (jpg, png).
I question whether its necessary to show such detail in a model. You can create a hatch that has the pattern layout you need, but to show the colors, you could use a detail drawing with notes on color placement and even include an image. Then, wherever that pattern shows up in your model, just refer to the detail.
Ed
How to post your code.
WeTanks
SUPER HATCH can help you.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
22muntasir
Community Visitor
Community Visitor
Thanks for the help everyone
nrz13
If it's always a linear element like your example, you could make an array or dynamic block that you could copy into a drawing when needed and then you just drag it out to the length you need.  Assuming that is the case, if you share your CAD file I can show you a couple of examples.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
