select last object created such as polyline
jalal.mousa
jalal.mousa
Hi There
is there a way a command to select last item/object created such as polyline using Autocad command
pendean
Community Legend
Community Legend
Most of the AutoCAD commands respond to LAST or PREVIOUS for a selection option (which will pick up a PLINE too)
https://www.cadtobim.com/object-selection.html#:~:text=6.%20Select%20Last%20Created,it%20will%20be%2....
and
https://www.cadtobim.com/object-selection.html#:~:text=If%20you%20want%20to%20modify%20the%20same%20...
OR.... are you perhaps having something way more specific going on, or a specific command/function?
Elaborate please.
Ed__Jobe
I answered your question in the VBA forum. It's not polite to ask the same question in multiple forums. If you made a mistake an posted to the wrong forum, then click the !Report button and ask the moderator to move it to the correct forum. Thanks.
Ed
How to post your code.
jalal.mousa
Hi Ed,
thanks for your answer
in my previous post they ask me to post in the proper forum VBA if this is coding question or AutoCAD if this related to program itself
so i did ask question in AutoCAD to learn about specific command that i can call and VBA to see if there is different way to do it
thanks for understanding
jalal.mousa
Thanks pendean
I tried last before but i don't see option to call last polyline
and previous not recognized
Kent1Cooper
First start a command that involves object selection, then when it's asking you to select objects, type L for Last.
Kent Cooper, AIA
pendean
Community Legend
Community Legend
@jalal.mousa I see your issue: you are incorrectly using LAST and PREVIOUS as if they are commands, when in reality they are sub-options AFTER you start a command like MOVE or COPY.
I take it you did not quite understand my last reply either. Sorry it was written with assumptions on my part.
I am going to guess at your actual intent-
You do not know there is a command call SELECT: when you activate this command then use LAST or PREVIOUS, you can get that PLINE selected and stay selected when you exit SELECT command. Look up usage in HELP.
Good luck.
