how can i remove the display scale message every launch
Message 1 of 14
iam fine with these scales i don't want to see this annoying message with annoying sound everytime i open cad
Replies (13)
Message 2 of 14
ennujozlagam
you can try to refer to this LINK and see if helps. thanks
Message 3 of 14
u didn't understand my answer i need to remove it with current scale setting
Message 4 of 14
ennujozlagam
did you go to the LINK. thanks
Message 5 of 14
Alfred.NESWADBA
The background information is that AutoCAD needs a minimum resolution to work well (and to be able to show ALL dialogs correctly).
When you have e.g. a resolution of 1280x1024 and your Windows DPI scaling is 150% then the resolution AutoCAD gets for dialogs is
1280/1.5 = 853
1024/1.5 = 682
Which results in a virtual screen resolution of 852x682 ... to less to present all dialogs correct inside the software.
As this would make a lot of users angry the warning message appears which gives you a valid description, raise the resolution or lower the Windows DPI setting so AutoCAD has a chance to work as expected.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 6 of 14
pendean
Community Legend
Community Legend
Fix the problem or live with it are your only two choices. The fixes are listed on that pop-up
Message 7 of 14
i don't know why u pople are talking nervously
i don't want company soluation.
is there any other alternative way to edit that
it might be fixed by editing like text file adding line command it might be simple but needs someone expert in that
Message 8 of 14
Alfred.NESWADBA
NO
- alfred -
Alfred NESWADBA
Message 9 of 14
RobDraw
Simple but needs an expert? That doesn't make sense, plus, you are talking to experts.
Rob
Message 10 of 14
ncthien
Community Visitor
Community Visitor
Message 11 of 14
didn't work
Message 12 of 14
RobDraw
Don't you understand that if you don't fix the issue there WILL be graphic problems?
Rob
Message 13 of 14
Iam replying to him
Message 14 of 14
RobDraw
I am asking you.
Rob
