AutoCAD Forum
How can I batch convert DWG files containing imperial blocks to metric blocks?
4 REPLIES 4
matthew_lieb
332 Views, 4 Replies
I have a folder called CAD_Library which contains 221 DWG files. In these DWG files are some symbols in the model space which were created using imperial units. While I am not sure if they are defined as blocks, the symbols in the DWG files are intended to be used as blocks. I am supposed to convert all of these "blocks" from imperial units to metric units and I have manually been doing this by entering each file and using the DWGUNITS command.
Is there a way to automate this process so I do not have to manually change the units for every DWG file? For example, is there a way to loop through the folder containing the DWG files and run the DWGUNITS command (with options 3, 2, 4, YES, YES, YES, YES) for each file automatically using AutoLISP or something else?
Is there a better way to batch convert all of these DWG files from imperial to metric? Or is there a better way to approach this assignment altogether?
4 REPLIES 4
pendean
in reply to: matthew_lieb
May I ask, why do you need to "convert" them? AutoCAD is designed to correctly scale them as you INSERT them by default, you just have to pay attention to a couple of settings.\
PLUS... I don't know what these blocks of your are, but I suspect 90% of them would not be actual correct METRIC sizing per industry standards, so that may be more of a future problem for you than an asset.
Example: lots of things are 4" tall, the rest of the planet calls 100mm the same standard. 4" is not exactly 100mm, it's a bit more. So it's not actually 'standard' anymore, it's a fudge.
Ed.Jobe
Besides changing the units, you may also need to scale the entities to suit, i.e. 1 inch does not equal 1 mm.
The easiest non-programming way to do this, is write a script (*.scr) to process 1 dwg. Don't forget to have the last line be QSAVE or SAVEAS "newMetricName".
Then use the ScriptPro program to run the script on a batch of files. It's just a single exe that doesn't require installation.
Ed
How to post your code.
matthew_lieb
in reply to: pendean
Thanks for your answer and the help!
I am not sure why they need to be "converted" if they can just be scaled when using INSERT.
And, you would be correct that these blocks are not correct in terms of the actual correct metric sizing. They are nowhere close actually. The blocks are just P&ID symbols which were modeled using imperial units but nowhere near accurate to the real dimensions. The only reason the dimensions are important as far as I am aware is to establish the sizes of the P&ID symbols relative to one another, for example I want pump symbols to be twice as large as valve symbols.
So, is converting all of these blocks an exercise in futility? Does it matter at all whether blocks are modeled as imperial or metric?
matthew_lieb
in reply to: Ed.Jobe
Thank you! While I am no longer sure that this is necessary per @pendean response, this is just what I had in mind.
Forma Design Contest
