Solved by alex101000. Go to Solution.
Hi @Anonymous,
Your post from April unfortunately didn't get any responses. Did you purchase the glasses or decide you decide to go with a different device? Can you share your decision and how satisfied you are with the outcome?
I tested the BT-350.
IMHO, to complete the work in AutoCAD is not enough screen resolution of 1280x720. You will need to connect the mouse bluetooth, on the sensor of the glasses themselves is not so convenient to work. You can use a remote desktop connection or an application for mobile platforms, and it has significant limitations. At the moment I see it possible to use the drawings for inspection.
It can be used to view 3D models on the ground by the customer, but Augmented Reality must be provided with an application, otherwise you will have to coordinate the image and the environment manually.
Moreover, it will be difficult to do this in bright sunlight - lack of brightness and contrast.
