File name desappears, replaced with the shortcut
Hello
I set favorites in Windows Explorer to point to different folders. So I created shortcuts on the desktop that point to my different folders with names in the clear. Then, these shortcuts were pinned in quick access to find them easily in the Windows Explorer.
In Autocad, in the file opening window, when I click on Favorites, I find all my shortcuts and with the text in clear. Great, I click on a favorite, I find myself in the right folder, but, because there is always a but, the name of the file disappears in favor of the name of the shortcut. To overcome this, you must copy the file name, click on the shortcut, and paste into the file name to return correctly. It's a bit difficult, especially when you have complicated names (graphic chart). This is not a problem of use because it works well with other software. If Autodesk could correct this slight bug.
edited by a moderator: originaly posted in french , english translation by OP kept
