File name desappears, replaced with the shortcut
patrick_35
Message 1 of 14
patrick_35
Hello
I set favorites in Windows Explorer to point to different folders. So I created shortcuts on the desktop that point to my different folders with names in the clear. Then, these shortcuts were pinned in quick access to find them easily in the Windows Explorer.
In Autocad, in the file opening window, when I click on Favorites, I find all my shortcuts and with the text in clear. Great, I click on a favorite, I find myself in the right folder, but, because there is always a but, the name of the file disappears in favor of the name of the shortcut. To overcome this, you must copy the file name, click on the shortcut, and paste into the file name to return correctly. It's a bit difficult, especially when you have complicated names (graphic chart). This is not a problem of use because it works well with other software. If Autodesk could correct this slight bug.
edited by a moderator: originaly posted in french , english translation by OP kept
Replies (13)
Message 2 of 14
john.vellek
Hi @patrick_35,
Please tell me which OS you are using. Windows 10 uses QUICK ACCESS instead of FAVORITES so I can try to test with that instead.  Please also tell me which version of AutoCAD you are using.
John Vellek
Message 3 of 14
patrick_35
Hi @john.vellek
I work with Autocad 19.2 and my os is Windows 10.
Message 4 of 14
john.vellek
Hi @patrick_35,
I don't want to sound too stupid here but is it possible to make a quick screencast video for me?  When I access my "Favorites" in the AutoCAD Open window, the file names look normal.  Perhaps i am doing this differently and want to make sure that I can get this to the team if it is indeed something that AutoCAD is doing.
John Vellek
Message 5 of 14
patrick_35
Hi @john.vellek
I'm sorry for responding so late.
No, you're not stupid, maybe it's me that I did not express myself.
Here's a screencast of the problem.
Message 6 of 14
alex101000
Please, try this solution.
  1. Create a new Library named how you want the shortcut to appear
  2. Go to the Properties of this new Library and add your intended target folder
  3. Change the library icon, if you wish
  4. Right-click on this new Library and choose 'Pin to Quick Access'
Message 7 of 14
patrick_35
Thank you for your reply, but that's what I did.
This does not prevent Autocad from changing the name of my file by the name of the shortcut.
The same manipulation made on Excel for example is not a problem.
It's not a big deal. When we know the problem, copy the file name before clicking on the shortcut, then paste to find the name, but it's boring in the long time.
Message 8 of 14
john.vellek
Hi @patrick_35,
Does this happen if you save in 2018 format?  I am wondering if the version change makes any difference.  In the mean time I will try to replicate this on my side too.
Thanks for the video.
[EDIT] Nevermind, I can duplicate this easily too. I will get this logged for the team to investigate.
John Vellek
Message 9 of 14
cadffm
You can do this with a unsaved file.
The save file dialog get the filename if you clicking on a simple lnk file.
I like the idea that adesk should fix this.
Acad (and other programs) should only take the filename if you hit on files with valid extension.
You can not save as lnk, so the dialog should ignore that file(name).
Sebastian
Message 10 of 14
patrick_35
Hello
@john.vellek
The format change does not change anything.
@cadffm
It's not just for save. I took this example which is the most telling. It's the same with a pdf print (DGW to PDF).
Message 11 of 14
GrantsPirate
In your screen cast you are selecting Save As so the file name will appear as the folder, as you show, because AutoCAD has no way of knowing what file name you are going to save to.  If you use the File Open and use shortcuts it will act differently and as expected.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 12 of 14
john.vellek
Hi @GrantsPirate,
I tried this with even a SAVE and any shortcut and discovered the same problem as described by @patrick_35.  I logged it for the team to investigate.
John Vellek
Message 13 of 14
GrantsPirate
The Shortcut name is a file, so if you click once it just puts that name in the File Name line, But if you click twice (since it is a shortcut) the name will still be there but the list of files available in that folder shows.
Or I am completely not understanding the issue.
GrantsPirate
EXPERT ELITE MEMBER
Message 14 of 14
patrick_35
Yes, the file name is replaced by the name of the shortcut.
When you open a file, the behavior is the same, except that you select a file and it is not relevant.
With a saveas, the file is renamed by the name of the shortcut.
We have the same problem when we create a pdf or a plt.
This is a problem related to the dialog box, not the features of Autocad.
