Hide Yellow squares
Hide Yellow squares
bcsnyder2
Hide Yellow squares
bcsnyder2
 Some of my dimensions and multileaders have yellow squares with exclamation points.  I have tried unsuccessfully to reassociate them to the object.  Is there a way to hide those squares?  When I am presenting a drawing to a client in Microsoft Teams it is disconcerting to have those yellow alerts all over the drawing.
cadffm
You can turn it off, so you will not see which objects are associated and which not.
ANNOMONITOR
Sebastian
bcsnyder2
???  I set annomonitor to zero (it was set at 2).  Now the yellow squares are still there, they just don't function.  How do I hide the squares?
Eureka -  Setting it to "-1" did the trick.  Thanks.
cadffm
Try it again with 0, it should works too!
Default is -2, what is the prefered value (if you want it off) for the most of us,
or -1, dependent on your wish to handle annomonitor when Model Documentation changes.
Annomonitor STATUSBAR button toggle turn it off/on
if you had value 0, it will change to the default 2 and next to to -2.
Sebastian
bcsnyder2
I don't know what is going on but the first time I set it at zero the
squares remained. I used regen to see if they would go away but they
didn't. This time when I set it at zero it worked. I am using 2024 and
there are some display issues so perhaps the squares weren't really there.
