Hide Yellow squares
bcsnyder2
Hide Yellow squares
bcsnyder2
 Some of my dimensions and multileaders have yellow squares with exclamation points.  I have tried unsuccessfully to reassociate them to the object.  Is there a way to hide those squares?  When I am presenting a drawing to a client in Microsoft Teams it is disconcerting to have those yellow alerts all over the drawing.
0 Me gusta
Responder
Soluciones aceptadas (1)
464 Vistas
4 Respuestas
Respuestas (4)
cadffm
You can turn it off, so you will not see which objects are associated and which not.
ANNOMONITOR
Sebastian
0 Me gusta
bcsnyder2
Solución aceptada
???  I set annomonitor to zero (it was set at 2).  Now the yellow squares are still there, they just don't function.  How do I hide the squares?
Eureka -  Setting it to "-1" did the trick.  Thanks.
0 Me gusta
cadffm
Try it again with 0, it should works too!
Default is -2, what is the prefered value (if you want it off) for the most of us,
or -1, dependent on your wish to handle annomonitor when Model Documentation changes.
Annomonitor STATUSBAR button toggle turn it off/on
if you had value 0, it will change to the default 2 and next to to -2.
Sebastian
0 Me gusta
bcsnyder2
I don't know what is going on but the first time I set it at zero the
squares remained. I used regen to see if they would go away but they
didn't. This time when I set it at zero it worked. I am using 2024 and
there are some display issues so perhaps the squares weren't really there.
0 Me gusta
