Hi, two things please
The first is when I press the right key --> PLOT I always get the following warning and I'm happy to get rid of it:
the options is : YER / NO
The second is when I export a PLOT, I want the name of the PDF file I export to be saved as the name of the LAYOUT, but currently it is as the name of the DWG file, can I change it?
Many thanks in advance
These links will help:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
@stavjan19989 Hello, do you still need help with this question?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
