sheets set manager to pdf
paul_braithwaite2
paul_braithwaite2
AutoCAD 2023
I’m using Sheet Set Manager to print from AutoCAD 2023 to Kofax pdf. The problem is, the total number of comments it produces. See attached. I must delete these comments and it takes forever. Is there a way to avoid printing the comments to the pdf. I have tried typing PDFSHX and entering 0, but this doesn’t seem to work.
Any help or suggestions appreciated.
pendean
Community Legend
Community Legend
Start here, but don't ignore the #1 fix (Autodesk says so, so you truly don't have a lot of choices if all else fail)
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Drawing-text-appea...
paul_braithwaite2
Thanks Dean,
Much appreciated.
I also found that if I print the 'Kofax pdf' as a 'Power pdf' it gives me the options to just print the document content and ignore the comments. A work around I suppose.
Cheers
