Help with OSNAP
Help with OSNAP
robFNUAY
Observer Observer
Help with OSNAP
robFNUAY
Observer
Observer
Hi There - When trying to move an object by a numerical value the object moves to a snap point instead (see screen capture video for an example). In the screen capture video, I use the move command and enter a numerical value of 60'-0", then hit enter. But, the object snaps to the endpoint of the rectangle at 66'-11". My APERTURE system variable is set to 5. My SNAPMODE variable is set to 1.
I know that I can resolve this by toggling OSNAP (F3) off, but I would like to avoid toggling OSNAP (F3) off every time I need to move an object by a numerical value. Is it possible to set a system variable to disable OSNAP when entering a numerical value, or a similar solution? Thanks all!
paullimapa
take a look at OSNAPCOORD
Paul Li
IT Specialist
@The Office
robFNUAY
Observer
Observer
Thanks @paullimapa! The value was 0, modifying that value to 2 seems to have worked.
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
cadffm
Hi Rob,
where you set it to 0 by mistake (perhaps), OPTIONS dialog.
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-2E780292-7D34-4A34-8CCC-82363D4F9092
Sebastian
