Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Help with OSNAP
Help with OSNAP
robFNUAY
Observer Observer
Help with OSNAP
robFNUAY
Observer
Observer
Hi There - When trying to move an object by a numerical value the object moves to a snap point instead (see screen capture video for an example). In the screen capture video, I use the move command and enter a numerical value of 60'-0", then hit enter. But, the object snaps to the endpoint of the rectangle at 66'-11". My APERTURE system variable is set to 5. My SNAPMODE variable is set to 1.
I know that I can resolve this by toggling OSNAP (F3) off, but I would like to avoid toggling OSNAP (F3) off every time I need to move an object by a numerical value. Is it possible to set a system variable to disable OSNAP when entering a numerical value, or a similar solution? Thanks all!
paullimapa
take a look at OSNAPCOORD
Paul Li
IT Specialist
@The Office
robFNUAY
Observer
Observer
Thanks @paullimapa! The value was 0, modifying that value to 2 seems to have worked.
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
cadffm
Hi Rob,
where you set it to 0 by mistake (perhaps), OPTIONS dialog.
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-2E780292-7D34-4A34-8CCC-82363D4F9092
Sebastian
