AutoCAD Forum
Help with Customizing Ribbon Tabs
2 REPLIES 2
233 Views, 2 Replies
I'm using Autocad 2016 Mechanical and I'm having trouble creating a custom tab / ribbon. I've opened CUI, created a new ribbon tab, created 2 new ribbon panels and drag/dropped them into my ribbon tab. I drag/dropped my ribbon tab into my workspace and selected "customize workspace" and checked the tab I created to be displayed. It is still not appearing at the top of my AutoCAD workspace. In the same way that you would click, "Home" and then "Line" I want to be able to click "FE Commands" and select a lisp command from my Ribbon Panel. Could someone explain to me what step I am missing? I'll include pictures, the first shows I have created the Ribbon Tab and Ribbon Panels. The second picture shows the Ribbon Tab is listed in my Mechanical Defaul (Current) Workspace.
2 REPLIES 2
TheCADnoob
Im kinda green with the ribbon and had issues setting mine up but i finaly got it off the ground. did you add the panel and tab to the ribbon display? if you right click on a blank ribbon space you can see which panels or tabs are shown.
CADnoob
in reply to: TheCADnoob
I figured it out! I had to refresh the ribbons. I had exited autocad 2 or 3 times but they never actually "refreshed". I changed from Mechanical to 3d and back to mechanical and the ribbon tab appeared!
Forma Design Contest
