AutoCAD Forum
AutoCAD 2016 crash
2 REPLIES 2
UNISOL
337 Views, 2 Replies
AutoCAD 2016 crash
My crash was a total hang up during switching from "model" to "Layout".  All other applications worked but the only way I could unfreeze AutoCAD was to logoff and reload.  In the past I have been able to find an autosaved file or a recover file.  This time I couldn't find a receover file nor any recent auto-saved file - despite I have an auto-saved every 10 minutes..  The only file that seems to be what I'm looking for is an "UNDO.ac$" of size similar to the file I lost!  But a simple name change didn't work this time.  Have I lost all today's work or is there some way to unlock the "UNDO" file and revert it to a "dwg" file?
2 REPLIES 2
pendean
in reply to: UNISOL
Open WIndows Notepad, drop the ac$ file into it: is the first word at the top something like AC1027 or similar digits? If not, it's not a valid DWG file.
IMHO you should restart your PC (resets OS), not just log out and back in which does little to reset much.
UNISOL
in reply to: pendean
Thank you.
There were several AC files but they had 0 size.  The only one of size was called "UNDO".  When I tried to open the ac$ files all gave , "not valid file" message.    What was strange about the whole hangup was that despite I have 10 min interval auto-saves there were no saved or backed up files ... ie no restore filed available.
I simply logged out because that usually is enough to free up applications.
Also by re-stating computer I noticed all the ac$ files I did have were obliterated ...
In the end I re-did my work manually.
AutoCAD Inside the Factory
