help window
help window
I AM HAVING TROUBLE GETTING THE OPEN FILE WINDOW. WHEN I GO TO "OPEN FILE" THE USUAL OPEN FILE WINDOW DONT APPEAR TO ALLOW FOR SELECTION OF MY FILES. ONLY THE COMMAND LINE POPS UP. "ENTER NAME OF DRAWING TO OPEN". IF ANYONE OUT THERE KNOWS THE REASON PLEASE ADVISE. MUCH APPRECIATED.
Patchy
FILEDIA and type in 1
AHHHH THANK YOU VERY MUCHO Smiley Very Happy
And again.........Brilliant
BeKirra
@Anonymous wrote:
... WHEN I GO TO "OPEN FILE" THE USUAL OPEN FILE WINDOW DONT APPEAR TO ALLOW FOR SELECTION OF MY FILES. ONLY THE COMMAND LINE POPS UP. "ENTER NAME OF DRAWING TO OPEN".
There is no doubt  that "Filedia" is the answer.
But it looks likely there are some reasons for the Open dialog (window) suddenly disappearing.
A common cause is that an add-on (Autolisp or other application) was loaded and it sets "Filedia" to "0" and after the execution it doesn't set it back to "1".
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
