Custom Line type with open text field
Jemauk
Message 1 of 11
Jemauk
I am putting togather an ALTA survey for a building in our local downtown.  I have multiple Sanitary Sewer lines around the building that are all different sizes.  Is there a way I can make a line type that will prompt me to enter the text I want?  I would not like to have to make a linetype for all these different size sewer lines.
Thank You,
Joseph Mauk
2014 C3D
Replies (10)
Message 2 of 11
leothebuilder
If you have Express Tools check out the MKLTYPE command.
No way you can make a linetype that includes editable text upon insertion. (unless maybe customization)
Doesn't C3D come with a bunch of these linetypes?
Message 3 of 11
Jemauk
None of the linetypes that come with C3D has a spot for editable text at the time it is drawn.  I know how to make linetypes that reflect the different size sanitary lines but I would rather make a linetype that asks me what I want it to say than making 6 different linetypes. I rememeber Land Desktop having a special linetype feature that would allow this.  Have they done away with it?
Message 4 of 11
leothebuilder
I don't know if such a line type existed.
Not in plain autocad anyway as far as I know.
Message 5 of 11
ВeekeeCZ
Maybe this feature will help you.
http://www.theswamp.org/index.php?topic=47058.0
Message 6 of 11
Jemauk
I can not access that link
Message 7 of 11
ВeekeeCZ
Sorry, you need to be registered.
But look at the gif what it's about.
Written by ronjonp, theswamp.org.
Message 8 of 11
Jemauk
Not exactly what I was looking for but I like the quickness of it.  Land Desktop had a linetype that when you when to use it in the command line it asked you what text you wanted it to display.  It did not make a "new" linetype like this progam does.  It was simply one linetype with a editable field for the text that was determined each time you used it.
*I have found an old user manual to Land Desktop 2000.  The lines I am refering to were called Special Lines and it was call Draw Line with Text.
Message 9 of 11
parkr4st
with Civil 3D very easily done if you mapexport the data to a SDF or shp file type and use the feature label capability.
dave
Message 10 of 11
Jemauk
Thats above what I usually do. Do you have a guideline that I can use to make sure I'm doing it right?
Message 11 of 11
parkr4st
could you post a dwg with one of each size pipe in it so we can look at the linework and and attributes or attached data?
dave
