AutoCAD Forum
help - units
22 REPLIES 22
Message 1 of 23
1907 Views, 22 Replies
help - units
My units are displaying in feet and inches instead of millimetres
All settings are on millimetres but lines are still drawn and measured in a different unit
Labels (1)
22 REPLIES 22
Message 21 of 23
peterm
Hi Racheal,
I've opened your drawing and there is a line with the dimension 10.0000 and when I measure it, it is 10.0000 units long.
What is it that you were expecting to see?
Message 22 of 23
in reply to: peterm
It was in the wrong units yesterday. the setting change seems to have worked but I've now found out how to modify the dimensions back to the way they were originally set.
Issue is resolved. Thanks everyone for your help 🙂
Message 23 of 23
nucliabrasil
Hi!
If you configured all correctly, type in prompt line command: dim update. This procediment ll' update dimensions datas.
I hope help you.
Forma Design Contest
AutoCAD Beta
