My units are displaying in feet and inches instead of millimetres
All settings are on millimetres but lines are still drawn and measured in a different unit
Hi Racheal,
I've opened your drawing and there is a line with the dimension 10.0000 and when I measure it, it is 10.0000 units long.
What is it that you were expecting to see?
It was in the wrong units yesterday. the setting change seems to have worked but I've now found out how to modify the dimensions back to the way they were originally set.
Issue is resolved. Thanks everyone for your help 🙂
Hi!
If you configured all correctly, type in prompt line command: dim update. This procediment ll' update dimensions datas.
I hope help you.
