AutoCAD Forum
help - units
22 REPLIES 22
Message 1 of 23
1906 Views, 22 Replies
help - units
My units are displaying in feet and inches instead of millimetres
All settings are on millimetres but lines are still drawn and measured in a different unit
Labels (1)
22 REPLIES 22
Message 2 of 23
RobDraw
Please provide screen shots to illustrate your issue.
Rob
Message 3 of 23
in reply to: RobDraw
Message 4 of 23
RobDraw
That's not your units settings. Type UNITS.
Rob
Message 5 of 23
At first it was in inches, so I changed it the millimetres (thought yay easy fix) but it doesnt change when I draw. (I have closed and reopened to let it update the changes but no change)
Message 6 of 23
RobDraw
It looks right from here. What makes you think it is wrong? (Include screenshots that actually show the error in your response.)
Rob
Message 7 of 23
you units are in millimetres. Also attached is an earlier drawing as it should be (in mm and with blue linear)
Message 8 of 23
RobDraw
Your not exhibiting the problem.
Rob
Message 9 of 23
All my settings say its in millimetres  but its not drawing in millimetres its drawing in feet and inches like my attachments show. what else can i send you or do to fix it? Im new to CAD so pretty lost with it all now the units have changed and i cant change them back. I appreciate any help i can get 🙂
Message 10 of 23
See attached a straight line with the linear. that unit should be i
n millimeters but isnt
Message 11 of 23
RobDraw
Nothing you've shown so far indicate feet and inches, sorry. If it were feet and inches, they would be labeled as such.
Good luck!
Rob
Message 12 of 23
the units are wrong to my settings. To show this I changed the Dim units from decimal to architectural but the units are still incorrect regardless of the dim units
Message 13 of 23
Message 14 of 23
Kent1Cooper
If the units in the images prior to Message 13 are incorrect, it's not in a feet-and-inches way.  What's incorrect about them?
Kent Cooper, AIA
Message 15 of 23
RobDraw
End all doubt and share the file.
Rob
Message 16 of 23
How do I share the file?
Message 17 of 23
pendean
Come to the website, find this thread, click on the REPLY button, option to add files is below he text box where you right your response.
Message 18 of 23
Kent1Cooper
in reply to: pendean
It's actually below the Screencast stuff that's immediately below the text box.  It looks like this:
Pick on the word browse if you want to navigate to where you have the file, rather than drag-&-drop.
Kent Cooper, AIA
Message 19 of 23
in reply to: Kent1Cooper
I hope I've done it right, it should it attached?
I have drew a line at 10 and measured with the linear. the line should be 10mm long but it isn't. All units setting are correct (from my thread yesterday) I dont know what else to change. Thanks for helping
Message 20 of 23
Just logged on and seems ok, although the the linear lines as they was and the colour. I can change each one individually but how do i change the standard settings.
Sorry I'm such an idiot - i'm new to this haha
Forma Design Contest
AutoCAD Beta
