Help on Arc or Fillet, with Photo Example
I need to redo the example shown on the photo.
My question is, How do I manage to get the arc or fillet (not sure which one to use) the one where it is labeled R.500 and R.300 to be exactly as in the example?
I give it a try but it doesn’t appear wide enough. May someone explain the step by steps. Thank you.
GrantsPirate
You draw the horizontal and vertical lines as shown and then start FILLET, specify a R of 300, pick the horizontal and vertical lines.  Restart the fillet command, radius 500, pick the horizontal and vertical lines.  The vertical lines will be 200 apart from each other.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
I tried what you replied, it reads radius is too large.
I believe it’s actually .500 and .300 as in decimal. I input these numbers and this is what it looks like (Photo attached).Not relatable.
I’m doing something wrong. Maybe the drawing units? (Settings on photo attached).
There was a typo in the book. It was actually a solid 3 and 5. Thank you for your expertise.
