AutoCAD Forum
Help, can't delete defpoint layer... (tried everything) (ENG-SPANISH)
5 REPLIES 5
1197 Views, 5 Replies
Good afternoon people ...
I have a problem and I really don't know how to solve it, I have tried using the "laydel" command or with the command in Spanish "delete layer", but it is impossible for me to delete the DEFPOINT layer, the layer is deleted correctly but as soon as I create a measure or move some object the layer reappears ...
---------------------- SPANISH/ESPAÑOL ----------------------------
Buenas tardes gente ...
Tengo un problema y realmente no se como solucionarlo, he intentado utilizando el comando "laydel" o con el comando en español "borrarcapa", pero me es imposible borrar la capa DEFPOINT, la capa se borra correctamente pero ni bien creo una medida o muevo algun objeto la capa vuelve a aparecer....
5 REPLIES 5
cadffm
Right,
dont change Defpoints setting, keep on, unlocked and thawed.
It is a system layer for system only, it needs defpoint layer for dimensions objects.
Sebastian
imadHabash
When you create dimensions in AutoCAD, the dimensioning components such as extension lines, arrowheads, dimension lines, and dimension text are placed on the current layer. The first time dimensions are added to a drawing, the software also creates a special layer named "DEFPOINTS". This layer holds the "definition points" for the dimension. By default this layer does not and cannot be made to print.
Imad Habash
Johanna_Esteban
Hola @Anonymous,
La capa Defpoints aparece al crearse una dimensión.
Puede borrarse cualquier capa, contenga o no elementos, mediante tel comando LAYDEL (puedes invocar cualquiera comando en inglés si antepones guión al piso).
Y si definitivamente no quieres la capa, tendrás que estarla borrando frecuentemente mientras acotes.
Saludos.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
in reply to: Johanna_Esteban
Thanks for all!
Gracias Johanna, ahora entiendo que es una capa del sistema, sin embargo cuando uno quiere borrar una capa por ejemplo el layer 0 o defpoint, al escribir "laydel" el mismisimo layer 0 no aparece en pantalla para eliminar, no se el porque pero por algun motivo no aparece, pero ya me quedo mas tranquilo jaj!
Johanna_Esteban
Hola @Anonymous,
La capa 0 tiene características especiales, es la que aparece al abrir un archivo en blanco (porque el alguna tienes que dibujar para empezar).
Y una particularidad en los bloques, si las entidades internas están en la capa 0, al asignar una capa al bloque, éste tomará las propiedades de dica capa como color, tipo de línea, etc. (que puedan ser aplicadas).
Mientras que si internamente corresponden a otras capas las entidades, externamente no sucederá.
Y no, no es posible borrarla.
Saludos.
Johanna Esteban
Forma Design Contest
AutoCAD Beta
