AutoCAD Forum
HELP AutoCAD Non-standard colors don't take grayscale
6 REPLIES 6
alessandro2
419 Views, 6 Replies
Hi everyone,
I ask for your help. Maybe you can save me 🙂
In my work I receive floor plans from architects or other people on which I have to integrate our technologies and then print our drawing in PDF.
To highlight our integrated devices I created a ctb that puts everything in grayscale and that leaves active only some colors (240 red, 152 blue, etc etc) that I use for my layers.
The problem is that in the drawings I receive many times in the model or in the blocks they use shades of color (for example 255,127,0) and the ctb does not recognize it as a color to replace with the gray scale so I have to manually select the objects or modify the blocks to return them to the standard colors so that they become gray.
Isn't there a simpler method?
Thanks!
Labels (1)
6 REPLIES 6
pendean
in reply to: alessandro2
Basic AutoCAD 101: TrueColors / RGB colors like 255,127,0 are never influenced by a CTB plot style table. Never ever.
You either need to change those colors to ACI colors 1 through 255, or you need to master and learn to use STB plot style tables instead.
paullimapa
alessandro2
in reply to: pendean
I agree with you. Unfortunately, making architects understand that this is not the way to work is not so simple and sometimes not even possible... 😞
pendean
@Anonymous perhaps you need to up your game, explore more tools and program features like https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-131E3BBB-A28A-40BC-BDC5-A4486C1E2DBE
Own it, don't be a bystander 🙂
cadffm
>>" which I have to integrate our technologies "
Are you not using XREF technology?
XREF architects DWG,
Take a look at XREFOVERRIDE
at set Xref layer colors, in your DWG, to ACI
Sebastian
RobDraw
That shouldn't matter.
Rob
Forma Design Contest
