Hi everyone,
I ask for your help. Maybe you can save me 🙂
In my work I receive floor plans from architects or other people on which I have to integrate our technologies and then print our drawing in PDF.
To highlight our integrated devices I created a ctb that puts everything in grayscale and that leaves active only some colors (240 red, 152 blue, etc etc) that I use for my layers.
The problem is that in the drawings I receive many times in the model or in the blocks they use shades of color (for example 255,127,0) and the ctb does not recognize it as a color to replace with the gray scale so I have to manually select the objects or modify the blocks to return them to the standard colors so that they become gray.
Isn't there a simpler method?
Thanks!
Try solutions on this thread
>>" which I have to integrate our technologies "
Are you not using XREF technology?
XREF architects DWG,
Take a look at XREFOVERRIDE
at set Xref layer colors, in your DWG, to ACI
Sebastian
@alessandro2 wrote:
I agree with you. Unfortunately, making architects understand that this is not the way to work is not so simple and sometimes not even possible... 😞
That shouldn't matter.
