Hi, I am constantly having Autocad crashes I can not work more than 10 minutes and have a crash. I remember this never happened to me when I used Autocad 2009. But with this new release is happening all the time. What should I do?
Thanks, the only drivers of the graphi card I always update is from nvdia web page I don t know if there is a specific driver for Autocad in Autodesk web page.
I also never heard that of the cores, so I don t know if this make something.
I will try to prove turning off the wardware acceleration and see what happens. Does the adaptive degradetion make something? I have it set to 5.
I atached you the task manager with Autocad running.
That is ok, and if you have the newest driver installed (and the crashes occur) try an older one.
Yes, besides of that all is written in the help (what it does exactly) I would set it to default.
Ok, it seems no other process to block AutoCAD, so no new insights based on that.
- alfred -
Ok, I will try this week with this things and I will let you know how this continues.
