AutoCAD Forum
Help Autocad crashes
22 REPLIES 22
Message 1 of 23
fprico
3277 Views, 22 Replies
Hi, I am constantly having Autocad crashes I can not work more than 10 minutes and have a crash. I remember this never happened to me when I used Autocad 2009. But with this new release is happening  all the time. What should I do?
22 REPLIES 22
Message 21 of 23
fprico
in reply to: dgorsman
Thanks, the only drivers of the graphi card I always update is from nvdia web page I don t know if there is a specific driver for Autocad in Autodesk web page.
I also never heard that of the cores, so I don t know if this make something.
I will try to prove turning off the wardware acceleration and see what happens. Does the adaptive degradetion make something? I have it set to 5.
I atached you the task manager with Autocad running.
Message 22 of 23
Alfred.NESWADBA
in reply to: fprico
That is ok, and if you have the newest driver installed (and the crashes occur) try an older one.
Yes, besides of that all is written in the help (what it does exactly) I would set it to default.
Ok, it seems no other process to block AutoCAD, so no new insights based on that.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 23 of 23
fprico
in reply to: Alfred.NESWADBA
Ok, I will try this week with this things and I will let you know how this continues.
Forma Design Contest
AutoCAD Beta
