AutoCAD Forum
Having the dimension line at specified distance from the measured line,
5 REPLIES 5
JamaL9722060
1414 Views, 5 Replies
This is the second time I’m highlighting this isssue
In the attached screenshots, I wanted the dimension line to be at 0.4 meter from the measured line but sounds not to work.
As the AutoCAD prompts for the “specify dimension line location or” I typed “0.4” but the dimension line is located at 0.36 from the measured line.
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
5 REPLIES 5
dmfrazier
in reply to: JamaL9722060
Using 2013, I get similar results.  After several trials, some dragging the dim above the object, some dragging the dim below, the results were consistently inconsistent.  I cannot tell what AutoCAD is doing, or how it decides where to actually locate the dim line.
nestly2
in reply to: dmfrazier
 I think I can help with that one.   The distance you type is the distance from the 2nd pick point, through the cursor at the moment you press <enter>
To place the dimline at a specific distance, pause long enough to set a tracking point then pull away in the desired distance before entering the offset distance.
pendean
DIMFXL and DIMFXLON variables to set exact dimension line extension sizes perhaps?
JamaL9722060
in reply to: nestly2
Many thanks nestly for the help. It works fine and resolve my issue.
Thanks are extended to dmfrazier and Saadallah
Best
Jamal
Jamal Numan
Thank you for the solution!
AutoCAD Inside the Factory
