hatch - using a block containing text as a boundary
MaccyDee
MaccyDee
selecting a boundary or internal point abd a block as a boundary (which consists of a circle with a text attribute).
Prior to 2025, you could remove just the text from the boundaries, and it would just use the circle to draw the hatch, now its selecting both items as the boundary but you have to;
  • Remove the block as the boundary
  • exit hatch
  • re-select the block as a boundary
  • then remove the text box boundary
  • then sometimes re-select the circle boundary again
pictures attached of what i want vs what i get. + cad file with a example
if anyone has any ideas of a pick order or settings to get back to the old way or to avoid this issue all together would be grand.
paullimapa
you should report this to Autodesk so they're aware of the difference with previous version hatching vs 2025
Paul Li
IT Specialist
@The Office
pendean
Community Legend
Community Legend
@MaccyDee We are all end users like you in these forums, Autodesk does not look here for anything other than making sure we are not torching the place 🙂
Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
jreidKVSUZ
Here is another trick you can use. WIPEOUT.
I took your block and added a Polygon Circle, then used Wipeout.
Place this in your block and use the Draworder Command and make it go behind the Text and Circle.
By doing so, when hatching you only have to select the Rectangle's line and ignore the block with the Text inside.
How to make:
  1. Enter the command POLYGON,
  2. When prompted to enter the number of sides, enter a value of 36 which will create a closed pline that looks just like a circle. ...
  3. Then use of the WIPEOUT command like you normally would, and choose Polyline option, then select the pline you created.
  4. Place this in your block and use the Draworder Command and make it go behind the Text and Circle.
  5. Close and Save your block. Now Hatch without selecting the Circle with the text in it.
Example is attached.
Also, you have your Grid On, Not sure if anyone uses that any more. F7 to turn it off.
Beauty of AutoCAD... so many different flavors of how to get your job done.
Enjoy!!
JRR!!
