Part of polyline arc is missing in display.
txphan99KY2
txphan99KY2
Hi all,
I have encountered a pretty weird problem of part of the polyline arc is missing in display in certain area of the model view. Pictures are attached.
as you can see, it's the same two arc but one is showing fully and one is not. When I plot or copy it to a diffrent cad file it's normal but when I moved it back to that position, the line is again concealed. I look through the smoothness of curve in the display options but it doesn't help either.
Hope someone can help me on this.
Valentin_CAD
@txphan99KY2 ,
Welcome to the forum!
First, reset your UCS - see how in this link:
Second, set it to enabled in the Linetype generation:
Third, make sure your layer and linetype are correct.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
txphan99KY2
hi thank you for the solution!, looks like when I change the ucs, it interfere with the display of the arc
