AutoCAD Forum
Halftone(50% screened) Plotting issue
8 REPLIES 8
Message 1 of 9
dbartholPQYPW
420 Views, 8 Replies
dbartholPQYPW
50% screened (halftone) not working when using "By Layer". When I change plot style at the element level, the 50% screened plot style works. I've restarted checked the checked plot style location.
Tags (1)
Labels (2)
8 REPLIES 8
Message 2 of 9
pendean
in reply to: dbartholPQYPW
pendean
Community Legend
Community Legend
Can you share a portion of your DWG (and the STB file being used) that exhibits this issue?
Message 3 of 9
dbartholPQYPW
in reply to: pendean
dbartholPQYPW
I thought I did that. Here are the files as well as a pdf illustrating the issue.
Message 4 of 9
paullimapa
paullimapa
Just opened in my AutoCAD 2025 and plotted your dwg using your stb file and the 50% screen shows in the pdf
Have you installed 2025.1 update?
What is your PDF viewer?
I'm using Acrobat.
Paul Li
IT Specialist
@The Office
I'm using Acrobat.
Paul Li
IT Specialist
@The Office
Message 5 of 9
paullimapa
paullimapa
One more thing, in AutoCAD 2025.1 I can also visually see that the color on the triangle is gray and not solid black
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
Message 6 of 9
pendean
pendean
Community Legend
Community Legend
What does your PLOT command pop-up look like?
and PUBLISH (I assume you use that)?  I too have no issues with your STB file with your DWG file
Message 7 of 9
paullimapa
paullimapa
ok, I see the problem now.
Your Layer is assigned to Plot Style 50% screened - which does NOT exist.
But when you assigned the object at the element level the Properties window shows the correct name as Screened_50%
So once you correctly assign your Layer to Screened_50% then it'll work
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
Message 8 of 9
dbartholPQYPW
in reply to: paullimapa
dbartholPQYPW
Thanks. That did it.
Message 9 of 9
paullimapa
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
