New window of CAD window open, every time i open a new file.
aliahmedshaikDXC6Z
Message 1 of 10
aliahmedshaikDXC6Z
**** with this problem ... needed help ...
I tried of reset.. Still not working
I tried SDI = 0.. Still not working
I did complete re-installed the Autocad .... Still not working
My Autocad Ver- 2024 (New Edition)
Replies (9)
Message 2 of 10
cadffm
>>"every time i open a new file."
if you using the OPEN command in AutoCAD to open additional files?
Sebastian
Message 3 of 10
aliahmedshaikDXC6Z
no.. double clicking the Cad File in File Explorer ..
Message 4 of 10
cadffm
Explorer is not an Autodesk tool.
Do this: In Explorer, RightClick, Properties, [General]
Is it linked to AutoCAD Application, or to Auto DWG Launcher?
CHANGE it to DWG Launcher.
C:\Program Files\Common Files\Autodesk Shared\AcLauncher.exe
Sebastian
Message 5 of 10
aliahmedshaikDXC6Z
yes it is Linked to Autocad Application,
something is missing in file path location.
C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcLauncher.exe
i do hope this is correct..
Message 6 of 10
aliahmedshaikDXC6Z
Explorer is not an Autodesk tool. (Yes i do agree with you)
but working in multiple location of file is helpful from Explorer.
Working from Only one is good for OPEN command in AutoCAD. But multiple file different location is again a problem.
Message 7 of 10
cadffm
>ou can drag&drop files from Explorer to your commandline or applicationmenu[A] or to the file tab line
In version2023 or older you can also drag them to the START tab.
Very useful if you have multiple session open, side by side,
>>"i do hope this is correct.. "
Yes, is it working now?
Sebastian
Message 8 of 10
Valentin_CAD
@aliahmedshaikDXC6Z ,
If all options fails, contact Autodesk Support:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 9 of 10
aliahmedshaikDXC6Z
Registry edits solution 2:
The following example uses AutoCAD 2020. The value will differ depending on the version of AutoCAD, AutoCAD LT, or DWG TrueView.
  1. Exit AutoCAD.
  2. Press WINDOWS-R on the keyboard to bring up the Run window, enter REGEDIT and click OK.
  3. Navigate to and select:
HKEY_CURRENT_USER\Software\Autodesk\DwgCommon\shellex\apps\{F29F85E0-4FF9-1068-AB91-08002B27B3D9}: AutoCAD
  1. Edit the keys OpenDdeSvc and PrintDdeSvc to both have the value of AutoCAD.r23.DDE, (Items A and B in image below). Remember, this is for AutoCAD 2020. It is possible that no number is needed (i.e., change it to AutoCAD.DDE). Alternately, it may be necessary to find and implement the appropriate R value for newer versions of the software. (r24 for AutoCAD 2022, for example.)
  2. If necessary, edit the path to the application which is specified for OpenLaunch and PrintLaunch, (Items C and D in image below) to make sure it goes to the correct acad.exe.
By this solution i did solved my problem.
Message 10 of 10
chuck_williamsJ2DJ2
Community Visitor
Community Visitor
this worked perfectly. thank you!
