Hi All,
I'm sure i just need educated...
If i select an object, pick one of the grips, tap the space bar once to go to the "move" option and then hold down the ctrl key to make copies of the object...
Well, i get copies but they seem to be snapping to some invisible polar grid. In fact, if i then put aligned dimensions on, i get two dims alternating at 45 degree intervals.
Can i turn this behavior off and just place copies at random locations?
Sal
Solved by maxim_k. Go to Solution.
Hi Sal,
Just release Ctrl key after you create first copy of object and continue to create copies without invisible grid.
Maxim
Thanks Maxim,
That really was easy. But now i have to know, what was defining the "invisible grid"? I'm guessing here but suspect some system variables? If so, i may be able to use this to my advantage.
Sal
