AutoCAD Forum
Grib point in dimension doesn't work
1 REPLY 1
210 Views, 1 Reply
hi, I have a problem that I want the upper dimension  to be like the lower dimension  ( I explained in the attached image) but when I select the extension leg and push the grip the dimension rotate I don't know what is the problem image.png
Tags (3)
1 REPLY 1
Alfred.NESWADBA
I can't reproduce this, when I use the left grip point you marked in your screenshot the text rotation angle stays the same
If you mean that not the dimension you marked in the screenshot, but the other dimension should be modified then please recognize the difference between these 2 dimension types, one is a "rotated dimension" (the one with the rotated text) and the other one is an "aligned dimension" which means the complete alignment has to follow the angle between the 2 measure-points.
So decide (before you create dimensions) if you need a rotated or an aligned one 🙂
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
AutoCAD Beta
