AutoCAD Forum
giving a 0 on Z
13 REPLIES 13
Message 1 of 14
2488 Views, 13 Replies
giving a 0 on Z
hey, when I started working on my new project I imported a landscape that included "z" lines.
this somehow affected me workflow and other 2d lines got a "z" factor to them.
in order to try to get all the lines back to Z-0 I tried FLATTEN but that didn't work ether.
I know there is a way to download and install a command that gives the lines chosen a 0 on their Z factor.
can anybody help me download and install this?
thanks!
13 REPLIES 13
Message 2 of 14
Alfred.NESWADBA
If you have the same object types then select them and edit the Z-value in the property window.
For lines: select lines and edit Start-Z and End-Z value to 0
For polylines: select them and edit the elevation value to 0
What does that mean? Have you got any messages from AutoCAD why it does not work, any informations, any error messages, ...?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 14
in reply to: Alfred.NESWADBA
I didn't get any messages from autocad.
I'm looking for a command that flattens the lines to have a zero factor for the hole image.. I don't have the time time to give every line a start and end value (nor I know how to). this is an already complex sketch that and going over every line is something I can't afford doing.
Message 4 of 14
Alfred.NESWADBA
Command _FLATTEN does that, if it does not give any message in your command line it should have worked.
Can you upload the drawing that does not work with that command please?
I have never thought about doing that by selecting every single line 😉
Use command _QSELECT to get all objects of type "Line" selected ... and then use the property window to modify all Z-values with one step. So it's a 10 second job.
- alfred -
Alfred NESWADBA
Message 5 of 14
Flatten doesn't do the trick(don't know why..).
I tried what you suggested . It didn't work 😞
Message 6 of 14
Alfred.NESWADBA
>> It didn't work
I can't see your system, so I don't know what you did and I don't know what happened then and so I don't know why "it didn't work".
We need a bit more info, always with the thought that we don't sit beside you and can follow what you are doing and how AutoCAD responded.
- alfred -
Alfred NESWADBA
Message 7 of 14
Message 8 of 14
There are still a lot that is not in place.
Message 9 of 14
Alfred.NESWADBA
can you please upload the drawing, in the screenshots I can see some objects that are close to vertical, but I can't select them, I can't see what they are, what their properties are and what happens when I try _FLATTEN with them.
- alfred -
Alfred NESWADBA
Message 10 of 14
JoeVernice
Try the attached autolisp file (Z0.lsp). I found this in an old forum post, flatten everything to Z=0 plane. Only select 2D objects, lines, circles, dimensions, etc.
JMV
Message 11 of 14
in reply to: JoeVernice
how do I get this to work on my drawing?
Message 12 of 14
JoeVernice
Download and save the file. Drag the file from windows explorer onto the drawing to load it. Enter Z0 at the command line, select the 2D objects in need of flattening and hit enter.
JMV
Message 13 of 14
Kent1Cooper
FLATTEN is that command, if by "the lines chosen" you mean already-drawn Lines [and other things] that you select.  I agree with Alfred -- what does it mean that it "didn't work"?  Did something happen that you didn't expect, or something not happen that you did expect?  Are the subject objects on locked Layers?  Etc., etc.
For drawing new Lines [and other things] without their being affected by different Z coordinates of things you are Object-Snapping to, read about the OSNAPZ System Variable in Help.
Kent Cooper, AIA
Message 14 of 14
Thanks! this is very helpful
Forma Design Contest
AutoCAD Beta
