AutoCAD Forum
From 3D to 2D
10 REPLIES 10
Message 1 of 11
saitoib
4768 Views, 10 Replies
From 3D to 2D
Hi all.
I want to create a 2D projection from a 3D object.
I have done a lot of research and the only way to do this in AutoCAD is to use the Flatshut command?
It seems that when I create a 3-sided view with Flatshut, I have to create each projection one at a time.
Is there a lisp or something that will automatically create a 3-dimensional view?
Thank you.
Saitoib
Tags (1)
10 REPLIES 10
Message 2 of 11
Alfred.NESWADBA
in reply to: saitoib
Instead of destroying the 3D object try command _VIEWBASE (and commands based on that) >>>details<<<.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 11
@Alfred.NESWADBA wrote:
.... Instead of destroying the 3D object ....
Are you confusing FLATSHOT with FLATTENFLATSHOT doesn't destroy the 3D object.
Kent Cooper, AIA
Message 4 of 11
oh yes, you are correct, my fault, sorry!
- alfred -
Alfred NESWADBA
Message 5 of 11
Kent1Cooper
@saitoib wrote:
.... I want to create a 2D projection from a 3D object.
.... when I create a 3-sided view with Flatshut, I have to create each projection one at a time.
It sounds like you don't "want to create a 2D projection," but rather multiple projections.  It's not clear to me what you mean by the "a 3-sided view" vs. "a 3-dimensional view," or whether those are the same.  Can you post an image or drawing showing the kind of result you're looking for?  If by "side" you mean orthogonal-direction projections such as in typical technical drawings, should it be from 4 sides, and maybe from 6 directions, rather than 3?  If by "3-dimensional" you mean something like an isometric view, from which point(s) of view?
FLATSHOT doesn't have a command-line version, so I expect it will be necessary to finish it out with the dialog box for each view, but at least the changing of view directions, and the starting up of FLATSHOT for each projection, can probably be automated.
Kent Cooper, AIA
Message 6 of 11
saitoib
in reply to: Kent1Cooper
@Kent1Cooper
I'm sorry I can't explain it better.
I want to create the plan view in image B from the 3D object in image A.
Saitoib
Message 7 of 11
Patchy
That is opposite from what the title said.
You wanted a bunch of 2d views to 3d.
Message 8 of 11
Valentin-WSP
@saitoib ,
This may be what you are looking for, read and see video:
AutoCAD 3D to 2D Convert - Create 2D Sections, Details, and Auxiliary Views from AutoCAD 3D Models
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 9 of 11
saitoib
in reply to: Valentin-WSP
@Valentin-WSP
Thank you for your guidance.
I have not used any 3D functions in AutoCAD before, so I had no idea about this kind of process.
I will study it.
Thank you very much.
Saitoib
Message 10 of 11
Alfred.NESWADBA
well, command _VIEWBASE and it's functions were already pointed out in the first reply in this thread (yesterday) 😉
- alfred -
Alfred NESWADBA
Message 11 of 11
saitoib
in reply to: Alfred.NESWADBA
@Alfred.NESWADBA
I'm sorry, my English is very difficult, so I missed it.
Saitoib
Forma Design Contest
