AutoCAD Forum
force autocad to work into a determinate z value
2 REPLIES 2
kibitotato
267 Views, 2 Replies
Is there any way to draw into a determinate z value even if I click into a line into another value? This must work for every operation. Block origin, array origin, pline, line... everything.... ¿Is it possible?
Tags (1)
2 REPLIES 2
Kent1Cooper
in reply to: kibitotato
Read about the OSNAPZ System Variable, which is for exactly that purpose.  But bear in mind that it forces Z = 0 in the current Coordinate System for Object-SNAPping results only -- you can still get something at other Z values when needed, by other means, such as by typing in X,Y,Z coordinates, or using point-coordinate filters.
Kent Cooper, AIA
ВeekeeCZ
AutoCAD Inside the Factory
