AutoCAD Forum
Finicky Importing Sheet into Sheet Sets for Web for AutoCAD 2023
0 REPLIES 0
Message 1 of 1
-Just-In-Time-
160 Views, 0 Replies
When trying to import an existing layout into the new Sheet Sets for Web (which is used for Autodesk Docs projects) following Autodesk's recommended workflow:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Working-with-Sheet... (workflow indicated under Import a Sheet to a Sheet Set)
Sometimes the Sheet imports into Sheet Set, and sometimes it doesn't.  Just wondering if this is normal (i.e. there are known glitches with importing sheets in the new Sheet Sets for Web) or if there's another reason why the sheets are not always importing correctly.
I've attached the Sheet Set and Title Block that I'm using.
Jay
0 REPLIES 0
Forma Design Contest
AutoCAD Beta
