Finding the Point Cloud Ribbon in AutoCAD 2021
Message 1 of 13
Does anyone have info on attaching a point cloud (.rcp file) in AutoCAD 2021? I cannot find the point cloud panel in the instructions I'm using. I'm not sure if it's because I am on the free trial version or if this is new to 2021. I was previously using the version for Mac, but switched to the original within a Windows environment. All the instructions/tutorials I have seen show a point cloud panel but I cannot find it anywhere nor can I use the command window to search for it or insert a point cloud that way. Any help is appreciated. Thanks!
Replies (12)
Message 2 of 13
thomas.stright
Insert Tab >> Point Cloud panel >> Attach
Message 3 of 13
cadffm
What kind of info? Start XREF or ATTACH command to attach a pointcloud.
Would be a good help to see what you see 😉 or?
It's 100% the same program, just another (30days) licence
Good choice
A Panel you can see by select a pointcloud in the drawing, it is a context sensitive panel only.
1. XREF <choose Pointcloud in the upper left button>   or ATTACH command
  if attached
2. Select the point cloud and you can see a point cloud panel
Hoping it is right, because i never used it.
Sebastian
Message 4 of 13
imadHabash
This is as designed starting from AutoCAD 2020, the Point Cloud panel has been removed from the Ribbon.
To attach point clouds to a drawing:
  • From the Ribbon, on the Insert tab, click on Attach and select the file type corresponding with Point Clouds (*.rcp; *.rcs) or All Files.
  • Enter the command ATTACH or POINTCLOUDATTACH.
Imad Habash
Message 5 of 13
cadffm
In plain AutoCAD 2021 ?
Can you share a screenshot of the whole program window
while on tab INSERT and <no objects selected>
? Thanks in advance
Sebastian
Message 6 of 13
I am trying to figure out how to create a file and attach the point cloud so I can ultimately create floorplans/3D models of the space. I originally photographed the spaces using a matterport camera, downloaded the matterpak, and created a point cloud in Autodesk Recap.
I attached a screenshot of what I see.
Message 7 of 13
Okay that is good to know. I have tried using the command window a few times and am also running into the problem that when I type something in and press enter, it doesn't look like the command is going through. Nothing happens. Screenshot attached.
Message 8 of 13
cadffm
Screenshot doesn't show the commandline after you pressed <enter>,
so it is the wrong timing for a screenshot.
And what is with the other commands you can read above?
_XREF or _ATTACH
Sebastian
Message 9 of 13
I have pressed enter but it isn't doing anything. Is there some way it's frozen or blocked? Here's another screenshot.
Message 10 of 13
cadffm
Sorry,
i can not see an entered command in your screenshots
and no informations about XREF and ATTACH commands.
Written communication is difficult and takes practice, I know that well - but that's how it is.
We can not see what you seeing, we can only see what you write down or attach to your thread.
Perhaps i missunderstood your screenshot, but it is what i see.
Q: In this situation (what shows your screenshot)
What happens if you try to click with the cursor to the editor or menu
Nothing?
And after [ESC]
Try it again,
Sebastian
Message 11 of 13
Yes, that's what I am trying to explain. When I press enter, nothing happens. The enter command doesn't go through.  When I click on a button in the ribbon, nothing happens.
What I am attaching is what I am seeing on my screen. The issue is that none of the commands are going through now. Do you know what I can do to fix this?
Message 12 of 13
cadffm
IF you can not start a command or selection without to press [ESC] first,
then:
Start the command and follow my hint to move a dialog window,
described here:
https://forums.autodesk.com/t5/autocad-forum/2018-add-delete-scales-popup-bos-missing-in-action/m-p/...
As you can read there, RENAME command is good for testing (IF you can see the Rename-Dialog),
If you understand what / how to do,
use it after you entered the PointCloudAttach command.
ALT+SPACE
M
Arrow key hit(1x)
then move your mouse (without pressing a key or wheel)
Sebastian
Message 13 of 13
cadffm
And what is the current state?
Tried to follow my hint above?
https://forums.autodesk.com/t5/autocad-forum/finding-the-point-cloud-ribbon-in-autocad-2021/m-p/9787...
Sebastian
