Find and Replace text in Default Value of Attribute Definitions
I am running into a problem with editing the default values of my attributes for literally thousands of block definitions in a drawing. The blocks have not been defined yet, as I am trying to streamline my block creation process. In AutoCAD 2015 I was able to use the FIND command to find and replace a part of the Default Values of any block definition of hundreds of Attribute definitions at a time using wild cards.
for example: Default values would end in "P3". I could FIND "P3" and Replace it for all selected attribute definitions with "Q1"
This is not currently working in AutoCAD 2016... I would prefer not to work in older versions. but has anyone else ever done this, and noticed the same thing? Any Suggestions?
Thank you.
EDIT:  Found my problem. All my attributes are set to invisible, and AutoCAD has the Ignore Hidden Items option chosen by default... DUH!
john.vellek
Hi 2bagz,
I'm glad you found your own solution!
John Vellek
