Find and Replace text in Default Value of Attribute Definitions
No aplicable
I am running into a problem with editing the default values of my attributes for literally thousands of block definitions in a drawing. The blocks have not been defined yet, as I am trying to streamline my block creation process. In AutoCAD 2015 I was able to use the FIND command to find and replace a part of the Default Values of any block definition of hundreds of Attribute definitions at a time using wild cards.
for example: Default values would end in "P3". I could FIND "P3" and Replace it for all selected attribute definitions with "Q1"
This is not currently working in AutoCAD 2016... I would prefer not to work in older versions. but has anyone else ever done this, and noticed the same thing? Any Suggestions?
Thank you.
EDIT:  Found my problem. All my attributes are set to invisible, and AutoCAD has the Ignore Hidden Items option chosen by default... DUH!
0 Me gusta
Responder
742 Vistas
1 Respuesta
Respuesta (1)
john.vellek
Hi 2bagz,
I'm glad you found your own solution!
John Vellek
0 Me gusta
