- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using AutoCAD 2024.
To make a long story short, I have a drawing which has many lines drawn at 0.05mm, but also has lines drawn at 0.09mm and 0.15mm. I would like to change all of the 0.05mm lines to 0.15mm. As far as I can see, the FILTER command does not have an option to select objects by lineweight. Is there some way in AutoCAD to select objects by lineweight, so I can do a blanket selection for all of the 0.05mm lines? I was not able to find any threads about this using the search feature when I searched "filter by lineweight".
Thank you for any help.
